1 - 2 of 2 Posts
So I got the 2013 running today, but it took some doing. I put back together the motor, hook everything up, and.....Nothing. Then I tried a number of things until I figured out the problem. If I unhook the single wire that is attached to the ignition and put power to it the thing starts.
Does anyone know what that wire does?
Does anyone know what this means?
THanks
not sure what you're refering to when you say "attached" to the ignition
if you mean ignition switch (key switch), then it would seem you've got a bad switch or an open circuit in that switch
i looked for the wiring schematic in the owner's manual for the honda harmony H2013HDA (not sure how many models there were, and oddly, it didn't show the schematic but in case it helps, below is link to the owner's manual I found
http://lawnandgarden.manualsonline.com/manuals/mfg/honda_1_2/h2013hda.html?idRes=6582707
1 - 2 of 2 Posts
