Hello!
I got sick of messy oil changes, and it needed the seasonal oil change, so I decided to change a few things.
The first thing I did was to make a drain pan for the oil filter. I used an old bar oil/chain lube jug, but I'm sure any half to one gallon jug would work. A bolt on the block holds it in place, and I contoured the center to match the filter, so the improvised drain pan stays in place.
As you can see, it works fairly well.
I always hole the filter so they drain completely, and you can see the factory oil drain.
Even with the starter off, it's hard to reach with an open end wrench, and it kept working its way lose. There was no way to get a deep well on it because of the yellow piece of plastic. Once, so much oil dripped that it caused the drive belt to slip. I had to use belt dressing to get the tractor to pull a hill.
These LF157F filters are made in America, and they're under four dollars. I've never used the ones $ears $ells.
I couldn't find the size elbow and straight pipe I wanted in regular steel, so I had to buy these. The elbow was made in USA, but the pipe was manufactured in Taiwan. I reused the factory petcock.
Here's the finished job, and no more messy oil changes with the dodgy plastic tube and petcock that was impossible to tighten.
I'm sure this was redundant for many, but there are those out there that are lurking... Additionally, if you're anything like me, I get as much pleasure reading about other people's work and eyeballing their photos.
Cheers and thanks for reading,
bolillo_loco
bolillo_loco
