I decided after filing the points that they should be replaced, Coil too just because. Of course they gave me the wrong ones, so I will get the right ones tomorrow.
What I was told is the point gap is .22, plug gap .25 and timing 10 degrees btdc, sound right? One more question, does this tractor have a ballast resistor? I seen a small ceramic deal on the back of the ignition switch. Is that it?
I would not trust anything the person at the parts store tells you.
The 2010 gas came with three different ignition systems and parts differ for all. The distributor can be Wico, Prestolite, or Delco. You only get correct parts when you correctly ID what you have.
2010 came new with a 6 volt coil regardless of what make system. Also came with a ballast resistor built into the ignition switch. When you turn the key to "crank" it automatically bypasses that resistor and sends a full 9-10 volts to the coil. All 12 volt systems crank at 9-10 volts. When running the resistor drops down voltage to the coil to around 8 volts. If the resistor was not there, the running voltage to the coil would be 13 - 14 volts.
Note that when the original IGN switches went bad, Deere sold new switches that used separate resistors that got remotely mounted.
Your 2010 with the 12 volt system uses the same 6 volt coil the older 6 volt Deere tractors use. Any generic coil sold for "12 volt with external resistor" IS a 6 volt coil.
Points for all get set at .022". Plugs .025" Timing is TDC when cranking and 26 degrees advance when running full RPM.
