2009 x324 John Deere Maintenance
2646 Views 6 Replies 2 Participants Last post by  VWcheats
I purchased a 2009 X324 trade in to JD dealer with 313 hours on it. It seems to start easily, no smoke cold startup, real clean no tears at all in seat no hood cracks, very minimal deck scrapes for 1500 bucks.
The dealer is just out the subdivision so I can drive it over this week if needed. The manual is pretty clear on zerk fittings. Is there any grease guns which allow you to get at tough grease fittings easier, maybe dumb questions but I need to get one?
What other items besides valve adjustment, manual says every 200 hours
should I have them do? Deck leveling check? K58 service? Plugs cant be too hard to do myself?
Is there a larger oil filter I can safely use can I run synthetic safely with 313 hrs ? The outside of tires are worn more than inside can I switch the fronts L to R, R to L? Though tires cant be too expensive.
Thanks the forum has been very helpful in a couple last posts 2 weeks ago when I was looking at a X324 with cracked hood cut off mower chute and cracked seat guy wanted 1700. I have a big 3/4 acre this should be fine for the job!
1 - 7 of 7 Posts
fuel filter looks like easy job
The tires look to wear fine after looking againso might just get new ones see some dry rot.
Looks like there is a black plug on top of tranny near Tuff Torq sticker? suck out as much as I can get replace just as much, then repeat a few times?
Most of the grease fittings on the X324 are pretty easy to get at. Which one's are giving you trouble? All grease GUNS are the same but what you can change that can make access easier is the hose and coupler. A longer hose will allow you to get in at the zerk while keeping the grease gun out and clear of the machine. You can also replace the standard coupler with a swivel style that can be rotated straight or at a right-angle.
I adjusted the valves myself on my X500. It's pretty easy if you are mechanically inclined and have the proper tools. I strongly recommend you purchase the Technical Manual before attempting. You will need a set of feeler gauges and a new set of valve cover gaskets. It's a little tedious getting the proper adjustment and it requires a bit of patience. The rocker lock nuts and valve cover bolts are supposed to be torqued so to do it properly you would want to use a torque wrench.
Deck leveling is a piece of cake. Just follow the procedure in the operator's manual.
The K58 is a sealed unit and requires no regular maintenance.
Changing the plugs is quite simple.
Not sure about a larger filter. There is no problem with the size of the OEM filter. I change the oil in my X500 every 25 hrs which amounts to twice per season.
Yes, you can run synthetic oil at any time after the initial break-in period.
If you simply swap the tires from side to side the same edge will be on the outside. The only way to reverse them would be to dismount, turn the tire around and remount.
Just gonna put on new tires and have dealer adjust valves thanks.
It mows uphill without any loss of power still seems a little underpowered. Do the throttle or foot pedal cables stretch and need adjusting?
Thank you
Dealer said the speed is normal they are set up to only go so fast so they cut even and have low end torque. The rubber cap is breather only and forget the valves if it’s starting fine running fine save your money. I like these guys gonna get a good going over new front tires call it a day
1 - 7 of 7 Posts
