My tractor usually runs pretty good but starting last fall it has been missing on a cylinder under load. I have replaced the spark plugs before and it helped but it still missed sometimes. This winter blowing snow it has been missing a lot while under load. I did notice that a plug wire was had worked itself loose from the plug cap, but I also noticed that the plug caps don't really fit snugly on the plugs. I use it quite a bit so the gas should be fresh and since it does it above and below freezing I do not really suspect water in the fuel. I plan to get some plugs and caps today - fill up on fresh non ethanol 91 and add a touch of Seafoam.
Are there any common issues with the LC Kawi motors that would make this happen? Trying to avoid a trip to the dealer if I can.
