I am writing on behalf of my friend who has a 2000 model Massey Ferguson 6265 that starts and runs fine, but none of the hydraulic is working including the power steering.
He had intermittently problems for two months before all hydraulic response was lost. In that period the hydraulics were jittery and gradually getting more and more unreliable until now.
Anyone with experience on where to start the problem solving? Or maybe recognize this behaviour? Any help or input would be tremendous.
Best regards,
Sindre from Norway (on behalf of Eirik from Norway)
-check hydraulic fluid level and if the fluid looks ok (not milky or lots of foam) Top it up and/or possibly replace it as necessary.
-replace the hydraulic filter (with a hydraulic filter, not an engine filter, you might get cross matched incorrectly, and it is bad for hydraulic systems to get an engine filter). If you do this, maybe cut open the old filter and see how it looks inside. Metal bits are considered bad.
After this, I think it comes to inserting a pressure gauge into the hydraulic system and seeing where you are getting pressure and where you are not. I'd start with right after the pump and work from there.
Thank you so much for both bump and reply. Great tips, ill check it out. I have also gotten multiple tips about a hydraulic pipe located underneath the seat inside the body, that could leak and fail. A design flaw they supposedly mended in 2002.
Anyone know where to access this vaguely described pipe/hose?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
My Tractor Forum
