Just thought I'd document a rare case of hydro problem that I witnessed at the shop today.
Unit: 2010 Cub Cadet 2554
Hours: 90.5
Complaint: customer stated lack of forward/reverse power when unit is cold.
Now, this Cub hadn't had a fluid or filter change at 90 hours, so when he brought it in, we immediately jumped on him for not servicing it, so that at the very least it would look good if Cub/MTD had any warranty concerns. We changed fluid/filter (fluid looked like liquid sin), and that didn't change a thing.
Took it out for a test run, and noticed that a whining noise was starting to develop, but then dissipated after it warmed up - and with the noise gone, hydro operation was back to normal. Hmmm....
Came back after Christmas and the head tech tore right into it. Took fender/seat pan off to access the hydro. He was prepared to take off the charge pump assembly to check the o-ring seal when he found the culprit.
The suction tube fitting was loose. That's it. There were no indications of fluid leaking anywhere, the hydro was dry as a bone on the outside, but the suction tube fitting at the hydro had backed off enough to suck air in until it got warm, at which point it would re-seal itself and presto! Hydro would act normally.
Tightened the fitting and on she went, happy as can be....
Hours: 90.5
