For those of you that have a 200 series tractor (e.g. 200, 210, 212, 214 216) with a mower deck bagger unit mounted on it, do you know if the rear Integral sleeve hitch kit can be mounted at the same time as the bagger unit? I had already installed the rear Integral sleeve hitch and rear hydraulic mount kit during my ongoing restoration, but I just bought a bagger setup for it and I think I noticed that the bagger bracket that mounts on the rear of the tractor seems to use the same bolt holes that the integral sleeve hitch does. Can someone tell me if it is doable to have both mounted at the same time, or whether or not I am wrong or right on this? See the photo below.
