Recently bought a 2 stroke Chainsaw, the previous owner says he bought it brand new and only used it once and then it sat in his basement for years with the same fuel in it. So needless to say it doesn't start.
I drained the fuel, replaced fuel filter, checked fuel lines for cracks, took apart and cleaned the carb. Then attempted to start it, it doesn't even try, however I can smell fuel coming out of the exhaust, so I know its getting gas.
I then put a new plug in it, same thing - doesnt even try... When I put the plug on the housing and turn it over, I see spark so i know the plug is firing... Dont know where to go from here?? Its getting Spark, its Getting Fuel cause I can smell it...
I even sprayed some Carb Cleaner down the carb to try and get it to kick over on its own, even if for just a second and it didn't even try then either.
I took the plug out and spun it over a good 8-10 times and i saw fuel mist coming out of the plug hole like normal... Put plug back in, 1 last try.. Nope still nothing...
Thing thing seems dead as a doornail, unsure where to go from here?
