1 - 2 of 2 Posts
So I dropped the deck and sharpened the blades. Like an idiot I forgot to remember what to hook the large PTO spring to. It is held on with a cotter pin on a bracket on the deck. Anyone have a pic or illustration ? The one in the owners manual is lame. Thank you.:thanku:
About 5 - 6 inches directly infront of the cable support bracket, there should be a 1/4 inch vertical post with a hole in the top. This 'post' is actually an extension of the axle of the front most tension pulley. The cable will pull back on the pulley, putting tension on the belt, thus moving the blades.
Atleast that's where my LT2000 'spring' goes. Yup, I forgot, too, but figured it out and it works.
1 - 2 of 2 Posts
