Tractor Savvy
Hello all, I have an Agway 2125 that I just mounted a mint condition Briggs and Stratton 11.5 hp motor onto. I sat down after putting it in, expecting to hear the marvelous engine spin to life, but instead got nothing. not even a crank, or any flywheel movement. Also, the solenoid didn't click, and I had to cut the housing off two wires, and wrap them up against each other. Please assist me by pointing me in the right direction, becaus I don't know where to go next.
The Magnificent
A complete model and serial number would be helpful so we could all be looking at the correct manual and schematic.
But at first thought, it sounds like your safety interlock switches are not satisifed.
Before messing with the switches I would suggest swapping the wires on the small nuts on the solenoid. You might have the polarity wrong there.
Tractor Savvy
Re: 1996 Agway 2125: need some help/pointers
I found out it's actually a 1996 Agway 2125, but here's the numbers:
Model:136L670G019
MFG Code:1A29613-0071
