1988 John Deere 165 Snow Plow Compatibility
500 Views 7 Replies 3 Participants Last post by  Herd of Deeres
5
Looking at a snow plow that is for sale locally but not sure if it will fit my tractor. Does anyone know if this blade will fit a 165? The seller doesn't know what it came off of.
Plant Yellow Bicycle part Grass Bicycle fork
Plant Grass Road surface Gas Waste containment
Wood Road surface Grass Plant Asphalt
Motor vehicle Plant Yellow Wood Gas
Grass Groundcover Gas Wood Cylinder
1 - 8 of 8 Posts
That is not the correct blade for your tractor. You can do a Google search for: gx018bd deere
Plant Wood Saw Monoplane Grass
Road surface Grass Tints and shades Plant Groundcover
the correct plow parts for a 165 will look like this.
Thanks for the pictures and advice. Any idea where to source on of those blades or the numbers to look for?
If you Right click the chart and pick "Open in a new Tab" it will be easier to read.
That is very helpful! Thank you
A direct fit serial number will start with M02690. Others may work too according to the chart above.
Font Rectangle Gas Motor vehicle Plant
1 - 8 of 8 Posts
