If you're good at that you could turn it into a cottage industry. We had a member years ago, AlaninVermont, that did that. I know there were about 10 members he redid cylinder for. IIRC it was a flat $100, but that was about 7 or 8 years ago too.I should be able to chuck this up in my lathe and open it up, than tig or mig it back together, was more worried about the seal availability, thank you
I'm following you. I maybe a few months behind you. I've been cleaning out the shed this week. I guess I got lucky last year. I was at an auction where there were 2, 332's and a 318. Both 332's had dual wheels on the back. A lot of stuff was inside the Ag Building. There was a set of ag tires with chains and nice wheels, think I got them for $40. When I got them home I noticed they had long carriage bolts through the holes for weights, or duals.. I think they were on the 318. The tires are loaded also. I'm building mine as a show tractor just to pull my Mini Hay Wagon, so I may put the duals on it. Anyway, I'm watching with interest every thing you do. Thanks for keeping track of the process.While looking for some of the parts we need I came across a complete H3 valve with handles and decided if I’m going to upgrade now is the time with me being this far in. This should be here soon as well so I started making my way into the belly of the beast to get to the Valve View attachment 2576453
View attachment 2576452 View attachment 2576455
The solid end of the cylinder is 1.200 from the end,I’ve done a few but not having a lathe ,I ground the weld down and used a cutting wheel to cut .100 into the cylinder and hit the solid piece,you could cut only 1 inch and that will give you a solid location to set it back up for welding,Found another leak under the steering cylinder, do we cut the welds to replace the seal(s) and tig it back together ? View attachment 2575345
