The tractor had a model 44 loader attached. It was probably no issue when starting tractor the pump was automatically engaged. I would have an issue with that. I just don't know why someone tore things apart and left them that way. I think this will be a good tractor when I am finished with it.
Today I got the exhaust adapters and intake manifold/carb removed from the engine. A couple more things to disconnect and I can lift the engine out of the frame. Need to drain engine oil. Once engine is raised I want to replace the oil pan then remove engine tins so I can pull the heads to scrape carbon off piston/head and replace oil filter adapter gasket. When reassembling I intend to check valve gaps and install new head, breather, intake, and exhaust gaskets. I need to order firewall insulator yet.
