1 - 6 of 6 Posts
· Lawnmower Collector
My 1986 suzuki quadrunner won't idle. I rebuilt the carb. And it still won't idle. Runs fine. But won't idle. Won't even attempt to idle. Please help.
Sent from the MTF Free App
sounds like the pilot jet still has crap in it, or at least the passage. You need to be really careful to get into every passage with a piece of wire to make sure there's no junk still in there. Have you tried adjusting the idle up to see if it might be an adjustment issue? I had a similar issue with a ski-doo that ran fine but didn't want to idle. I cleaned them but the problem persisted so i took 'em apart again and made sure to use a piece of wire to get into the pilot passage and sure enough, there was some crap i missed. After that it idled ok.
1 - 6 of 6 Posts
