missing spring order new one 923 0123 /723 0123 spring 4.5 in over all long removed battery plat and fuel tank mount spring tp brake arm in hole but no place else to connect it 3in gap from end of spring to the sterring mount assembly no place close to connect to . where does it go????????spring is 4.5 in long
It hooks onto the steering frame lip below the curved part of the frame.
the spring is only 4.5 in long and the distance from brake spring mount to steering mount is 8 in can not streach spring 4 in made a ext mount on steering mount to attach spring to.Have to put everything back together now and see how it works have to take pic
fixed the problem the brake control rod was not letting the brake assembly to return to proper pos causing the distance to be 8 in re adj brake assem and brake peddel moved back to normal pos and the 4.5 in spring was able to be installed. With this correction the shifting fro for to rev was corrected.Put everthing back together just have to put bat back in and try it out had a hard time trying to get rev and for not fast enough , the shifter on tran was not working right . thanks for all your inputs every one I may have adj the brake assembly too much when had it all apart to have the charge pump checked out
