I will give you the details on this 140...a neighbor noticed I liked John Deere tractors after he saw my 1957 620 in my shop one day so he stopped by to tell me about his little garden tractor he might want to sell. He purchased the John Deere new in 1975 serial number 068110M and he said it was one the last few hundred made (not sure).
He said he parked it in his garage in 1995, nothing was wrong with it and the only reason he parked was because he had a lawn service cut his yard due to his health and age.
I decided to go take a look at it and was happy to see it was unmolested, no breaks or welds, still has the original BF Goodrich silvertown tires on it and all the parts were there as far as I could tell, no rust and thank goodness he had it in a garage. Seat was in typical condition for the age.
He said all he ever did with it was cut grass, no other attachments ever used. I'm not sure of the deck size but it does have a john deere tag on the deck reading "H117L". Would this be a 48 or 50 inch cut deck?
I asked him how much? He wanted $800. I said since we live so close how about letting me take it home and see if she will start? He said ok.
I cleaned the plug, replaced the coil, removed the carb and cleaned it with gumout....put in a battery and it started right up.
For a couple of hours it smoked a little but after letting it run for a while it stopped....I was thinking the cylinder may have been rusty from sitting so long....I changed the oil twice to remove any rust or debris and now it runs perfect.
I went back and gave him $800. Was it worth it?
Also, what type of hydraulic oil/Transmission oil should be used? He said he always used RED automatic transmission fluid.
Another question is, on the frame where the muffler hole is drilled in the frame this tractor has another hole drilled below that one. I have looked at hundreds of 140 pictures online the last few days and have not seen any with two holes in the frame.
It looks factory, nice clean cut the same size as the muffler hole. (see pics)
