Hello, I recently purchased a 990 with a deck, blade, tiller and wheel weights off craigslist. It also came with a full set of manuals for the tractor, engine and implements. It has a 15hp Briggs engine with a Nov. 1971 manufacture date on it and has the three-bolt front wheel hubs on it. From what I have read, that leads me to believe it is a 1972 model year. I got a heck of a deal on it. It would barely run, was missing parts and needed help. First thing I did was install a new air filter and plug, and tuned the carb, now it runs great! I also replaced the front wheel hub bearings as two of them were broken and put on a set of R1 (technically I3) tires. It had truck tires on it when I bought it.The PO mounted a car battery behind the seat, unhooked the charging system, made some lift system modifications with a welder and a few other odd things here and there. She is definitely a work in progress, but what a great tractor this thing has been so far.
Next steps are finding an original gas tank (it has a 1 gallon tank off of some other machine) and correct oil dipstick, put the battery in the correct spot, rewire the entire tractor, adjust the motion control lever (it won't center properly and the tractor creeps), tighten the play in the front axle and adjust the governor. If anyone has a lead on a gas tank I'd really appreciate it. They seem to be very hard to find.
I know I will get this question, so I'll answer it here: The tires are a 7.6-15 Goodyear Sure Grip I3 tires. They are a little narrow for the rims, but I put tubes in them and had no issues mounting and seating them.
I'll post more pictures and progress when I have a chance to work on it. This will definitely not be a race to finish this tractor. Thanks for looking.
