1 - 8 of 8 Posts
I just bought a 1970 john deere 140 h1 for 200 bucks. The motor is blown Kohler K321AS 14 hp. I have the opportunity to buy a john deere 214 with a 14 hp Kohler K321AQS. Will the work with the 140. Thanks for all your help.
An early 214 engine should bolt in. A later 214 engine has mount flanges cast into the block that don't fit between the frame rails of the 140. They can be cut off to make it work.
Kohler K321AQS..........A denotes style of oil pan. Q denotes style of muffler. S denotes electric start. I would think it would bolt right in. May have to change muffler.
  • Like
Reactions: MARK (LI)
That's what I was thinking. The guy wants 75 for the motor it has no compression so I'm going to get and throw a rebuild kit in it and let it eat
Parts collector
You might have to bolt the 140 oil pan onto the 214 engine to make it work.
I pulled 16hp (K341) out of a 216 swapped the pan over and dropped it in a 300 and it fit fine.
No compression could just be a stuck valve. That's what was wrong with the 16hp out of the 216. I pulled the head and worked some lube into the guide and wala she was running. Been running for 10 years now with no problems.
The only other problem I could see would be the drive shaft connection on the flywheel. But you can swap that out also.
Heck if you found one you could drop a 16hp K341 in there also. ;)
No compression could also mean the ACR (Automatic Compression Release) is working! Bob
  • Like
Reactions: PA318Guy
Discussion Starter · #8 ·
Absolutely start with the easy stuff first.
1 - 8 of 8 Posts
