1 - 20 of 49 Posts
Found this non running. Got it home and cleaned the points put in fresh gas and it's a great runner.
Going for a full restoration.
Great find. Rock on!
Parts collector
cool! Gonna be nice when you are done with it! :thThumbsU
That belt wear on the axle does seem to be not uncommon...there is a youtube of a guy putting an axle out of a 1872 ( one inch spindles) on a 129...he does comment that the same thing happened to the point the axle was weakened and split..I just did the steering on a 129 and can't believe the difference...replaced the cam follower, tie rod ends and put a thrust bearing on, what a difference.....Also would you mind telling me what paint you are using?...I can't find it any where near me, and yours looks great... :congrats:
Discussion Starter #9
I'm using the Majic Cub cadet yellow from tractor supply.
It's been working really well for me.
I know it's not a close match to the original color, but it looks good enough to me.
So far I've painted a bunch of stuff with it and honestly it's good paint.
Any paint is only as good as the prep work.
Keep up the good work. Looks great
1 - 20 of 49 Posts
