1 - 2 of 2 Posts
Hello, new here. I have a1960 lawn-boy 8210 self-propelled with a C-41 engine. It has been sitting for 30+ years. I'm trying to get it running again. The piston was rusted and frozen, but I have freed it up using 1 to 1 ATF and Acetone. The cylinder will be fine, but the piston is shot and the rod is broken. I'm looking for those parts. I may have a piston - 3 ring, and rings, but no luck on the rod. Rod part number is 677452. Parts manual shows a different rod for the C-42 engine in the same diagram as the C-41. Looks like that is the only difference in the engines, the crank and piston are the same. The C-42 rod is 677966 replaced by 682864. The 677452 C-41 rod does not have the 33 tiny pins, the 677966 C-42 rod does. I have found some 677966 rods. The question is, will that 677966 rod work in the C-41 engine?
Thanks for your help.
Welcome to the forum. Good to have you on board. Keep in mind that new members are not allowed to post wanted to buy threads until they've been here 15 days and have 15 posts so lets keep this thread a "point me in the direction of parts" if you would please. You should copy/paste your post into another thread in the walk behind forum here
--> Walk Behind Mowers
1 - 2 of 2 Posts
