1956 4 cyl gas.
I have 2 questions; the first It surely has been asked, I've searched but did not find an answer: Oil. What kind of oil can I use. In my searches, people say 15w-40 but not in all seasons, they talk about zinc additives and flat tappet cam needing zinc additives. I'm confused...
What I'll do with the tractor is plowing some snow in the winter, and in summer use, wood splitting and some light duty work in the yard. Can I use one type of oil all year long or is it better one type for the cold season and one type for the hot season. I live in Quebec, temperature can drop to -20F. All I want is to use the good oil to avoid damage of the engine
Other question, the engine runs ok but is kind of sputtering at full throttle. The four spark plugs are new (autolite 386 copper). Compression is 150 psi on 3 cylinders and one at 135 psi. Before throwing parts at it, I wanted to know from you that knows those machines what to check first. Carburetor is clean, I'm using super (octane 91 gas) is it ok?
Tractor sat for 2 years outside, I cleaned the distributor, change fuel hose and filter, and it started right up.
Is the site OliverParts a good place to buy stuff without any trouble?
Thanks in advance and here a pic or the tractor
