Remove the oil filter, drain the old oil and get rid of both, some auto parts stores and TSC take used oil. Put a new filter on and add the correct amount of oil (I'd make one quart ATF). Run it like normal unless you added the ATF then drain the oil after running it about an hour to get rid of all the junk that was trapped in the engine.
