1 - 12 of 12 Posts
:banghead3, Let me start off by saying HELP. The following are pixs I took of the steering box. By all that is hole there should be a place to put a little oil in the box throgh the hole on the right side of the box. NOT happening. Either too much:drunkie:, or this is not a 51 8N steering box. Please someone shine some light on my problem. :thanku::crybaby:
Discussion Starter · #2 ·
Just to add insult to injury, the stamped numbers on the right side of the box are 125, I hope that helps. Peering with a flash light through the hole for where the oil is to go is only the flat top of the steering box. Please tell me I don't have a rare vintage steering box. Thanks guys for the help.
Retired - Veteran Mod
Right-hand side.
The bolt that holds the dash to the steering box... Remove it. That's where you put the oil.
Take a look at this picture of my tractor... the bolt with a grease zerk in it is the one that you will remove. It is a through hole into the steering box.
This is the bolt to look for in the above picture...
Right-hand side.
:ditto::ditto::ditto:
Did you make this bolt?
Or where did you get it? Great idea!!
I hear most people like to us JD cornoil or something like that. Thick but not to thick.
After reading a previous posts about lubing the steering box (8N), I made a bolt with a fitting. My first try was to drill the bolt and use a drive in 3/16 fitting. No good, the fitting just pulled out of the bolt when I tried to remove the grease gun.
NEXT: Got a new bolt, drilled it out (bench press), used a #3 drill, tapped it for a 1/4 inch threaded grease fitting. This worked out much better, the fitting stayed put when I pulled the grease gun off.
I got JD Cornoil lube from the local JD Dealer, $3 a tube. I bought three tubes...used two. Pumped it until it came out of the top of the steering column (with the steering wheel removed).
I did not. There's a guy that was selling them (at one time, anyway) on eBay. I don't remember now, if I bought from him... or had a (machinist) friend of mine make mine :hide:... hey... it's been a while!!!
I made one from the exsisting bolt, took a long time to drill through but it worked, than tapped it for a zerk, and i used a drill press to do it so it wasnt too bad.
It is one of those things Henry should have done but is easy enough for us to farmerize.
It looked pretty easy I figured if I could buy on on the cheap thats what I would want to do. ( I dont have a tap and die set...at least not yet.)
Discussion Starter · #12 ·
Thanks for all the help and pixs on the subject. I'll keep working on it. May have to remove a few things to get a better look inside that area. Thanks again to all.
1 - 12 of 12 Posts
