18hp vanguard briggs zero compression on one side
3625 Views 8 Replies 5 Participants Last post by  greenhobby
Other side is 150 psi.
I think i smell gas in oil.
Where do i start?
1 - 9 of 9 Posts
Take out plugs, put screwdriver GENTLY into spark plug hole of cylinder with no compression and turn engine slowly BY HAND and see if piston is moving. If no movement connecting rod is broken. If it moves we will go from there...
Sent from the MTF Free App
No movement. Broke a rod i guess. Rebuild time. I better look for a manual.
I can send you a Service Manual IF you like, address below, put in proper format and remind me engine model number and what you want.
Walt Conner
wconner5 at frontier dot com
Anyone got a short block 18hp horizontal vanguard? 1" shaft.
rod bolts let loose?
Looks like one did. The other broke.
Was low on oil too.
Wow, that's nasty... I hate to see that!
1 - 9 of 9 Posts
