Hello all,
I'm getting ready to start the power steering conversion in the 1886.....
I just purchased (and awaiting delivery) of a steering valve from surpluscenter.com
Link to the vavle: https://www.surpluscenter.com/item.asp?item=9-7666&catname=hydraulic
I also ordered a few small pieces (bearing, coupler for the valve...)
some of the questions that I have are:
1. Should I run the steering through the tractor's hydraulic system or through the loader's?
2. If I run it through the tractor's system, does anybody know how and/or where I would connect each of the five ports from the steering valve? (I don't know hydraulics and never worked on them)
3. Will a cylinder from another 1886 work for a steering cylinder? I have one from an old parts tractor and am low on $$$.
I'll post as many pics as i can and try to list the parts needed as I go.....I'll have to fab some brackets/mounting plates which will be new to me. Warning: they will not be pretty.
Deceased October 2017
All I can add is that my 1886 with P/S gets its power via the hydro. I know there are instructions for adding the original Bolens P/S kits posted somewhere .. but I'm not sure where ..
Does anyone else know ?? I'm sure that would be a BIG help adding yours :fing32:
Ken, you are correct it runs via the hydro pump.I added a pic of how it is setup.It runs from the control valve and then back to it.It is set up a little different on my 23 but it has the oil cooler setup on it.
