1 - 3 of 3 Posts
Does any body else have any problems with there lift cylinder creeping down on there cub after awhile. mine will be all the way down after a couple days and I dont like it to in case I need to move the tractor I cant. I do know the fluid and filter needs changed in the hydro not sure when it was ever changed but I might as well change it any way it works fine it just wont stay up...even running it creeps down. Is this a dying hydro or the fluid really needs changed? the hydro its self is good and strong it dosent creep it wines a little but I have not seen many that dont, the fluid level is full and it smells like the right fluid the only thing I can come up with is it needs a fluid and filter change im just not looking forward to it(did it once on a 129 I had and it was a pain but it was easy) Any body else got anything to add im all ears
Most Hydraulic Lifts will do that when Parked even On the Big Row crop tractors Running I never had it Happen
thanks Sergeant, the only reason I asked was a buddy of mine has a 782 and his has never creeped down the only other thing I can add is when I first got this tractor it had set in a garage for a year un touched and once i got it to run and used it the lift wouldnt pick up the mower deck i actually had to reach down to help it but after i used it for a couple hours it worked fine picking it up with no problem but that probably had to do with it not being ran in a year.
1 - 3 of 3 Posts
