Where did you come up with the fluid mixture ratio?
Texas grass hunting? Been so dry here my 185 has been out once in the last six weeks. Got more seat time plowing my leaf/clippings pile with my 214 getting ready for leaf season.im trying to FIND grass to mow its so much better!
90W x 2/3 + 30W x 1/3 = 70Wwhat is youre thought on mixing the oils that way.
There is a purge procedure. Its posted here somewhere but I don't remember where. Might try searching on "hydro purge."how did you purge the tranny??
I think I found it!! Many variations and the answer wasn't specifically for Deere, but I'm sure they're all similar.There is a purge procedure. Its posted here somewhere but I don't remember where. Might try searching on "hydro purge."
Ohh, that's cool!! How do you know if you have an Eaton hydro though?? Sorry about the can of wormsabout purging...thats frustrating,don't anybody listen...if u take the fender pan off there is a plug right next to fill tube ...take it out...add fluid slowly till it overflows...put plug back in...you are done ...no fighting anything..plain and simple...this is for eaton hydro's...put fender back on and go...i have never had one issue doing it this way
Most dealers will tell you not to touch it if its running fine. Eaton vs. Sunstrand hydro is determined by the location of the drive pulley (top vs. side). As usual I can't keep them straight to tell you which is which :duh:Ohh, that's cool!! How do you know if you have an Eaton hydro though?? Sorry about the can of worms. Also, would you recommend changing the fluid if the hydro is working just fine?
