1 - 3 of 3 Posts
Skidsteer lost drive and rolled towards house.Had to turn off ignition to stop my machine.recently replaced line with a made to order cut and fitted replacement line from dealers shop,heard that sometimes they don't clean out all the shavings and these can be the source of a problem.
Don't see how shutting engine off would stop anything! ---Not much details here to give a good idea, but, Check the new hose to see if it blew off, Is there air in the drive system? --- You didn't say which hose was replaced. ---- The wheel drive has 2 systems, one for each side, so loosing only one side will not make it run away. Each side is self-contained unit.
Not likely that drive chains would come off, even if they did shutting engine off would not stop the loader.
Check everything super good, and tell exactly what you find, we will try to help you but need specific info! Thanks!
1 - 3 of 3 Posts
