the 180 i just got,even with full tank the gas light stays on,is there a sensor that can go bad ?
The Admin from... Nowhere!
yes there is.... Here's the parts diagram for your tank (I believe... its the pic for the 175, but should be the same across the two close models). Parts 12a and 12b are the two different types of sensors you might have depending on the vintage of your machine:
If you haven't already checked out the JD online parts catalog, take a look at it here. It can be an invaluable source of information, particularly if you have to replace with a stock part....
Hope this helps...
just went to JD dealer,both sensors Not Available anymore...darn!!ebay special it looks like now.
