Hello all having issues with a 18 hp briggs intek too much compression won't spin over enough to start watched. Many YouTube videos about it to see if one did something different adjusted the valves both to .oo4 still hanging up checked the keyway. It's good. Pulled the oil pan off to check the timing marks on the crank and cam which were good also checked the compression release on the cam which is there and functioning don't know what else to check
