I have always had a starting problem if I didn't use my Cub often.
Now, I have a new starter,solenoid, battery and ignition switch. It started fine for about 2 months.
Recently, I had not used it for about two weeks and it would not start again. No dashboard ignition lights when on/start.
If "jump" the solenoid, the starter will finally kick in and then start with the key every time after.
There is no electrical corrosion on any connector or terminal. Everything tight
I cant figure this out. Thanks
