Drive out roll pins at each end of shaft.
Unbolt rags at each end.
Slide couplings and rags a couple inches back on shaft at each end.
Slide shaft forward into motor end bushing/bracket/drive plate to clear coupling at pump end and lift up and out then slide motor end of shaft out of motor.
Don't damage stuck roll pins, soak in penetrating oil and use roll pin punches, once mushroomed you gots problems.
Scott
Scott
