I have an old Simplicity 6500 series with a Briggs twin, vertical shaft engine.
Model is 402707 and the code says it was built in '88.
At the end of last season I was having some issues with this old mower and never quite got them resolved.
When I got it going this year it was still surging at idle but evened out with some choke. I checked the carb float adjustment which was definitely wrong. I readjusted the float to be as level as possible with the carb body, put everything back together and now it won't start at all. If I spray carb cleaner into the carb it will run for a second or two and then die.
I pulled the carb again and checked that the float and needle move easily.
I checked the fuel pump diaphragms weren't torn, (they were new at the end of last season and looked fine. No pin holes or tears that I could see.)
I also made sure that fuel was flowing freely from the tank fuel line before hooking it up to the fuel pump.
I can blow through the vacuum side line that runs from the fuel pump to the engine so I know that isn't blocked.
Even though fuel is flowing from the tank side line, there isn't a drop of gas in the carb bowl.
Should the bowl fill from gravity or does it depend on the fuel pump to draw it through?
I'm stumped. I'd really appreciate some other suggestions that I could try.
ADDED: I did check the solenoid too - I can can hear it click and I see the shaft move when I turn on the ignition.
