I was given a Craftsman garden tractor that someone else tried unsuccessfully to repair. Its engine is 28N707_0666-A1_970402Z0. The PO replaced the camshaft and tappets (I'm not sure why).
I replaced the battery, cleaned carb & gas tank. I also checked all wiring. It now has good spark and clean fuel at the plug and 100 lb of compression.
The problem is: When starting, it only occasionally backfires as if the timing is off. I checked the valve clearances and they seem OK. How can I check the flywheel timing and camshaft timing by doing the least amount of tearing down the engine?
Thanks you in advance for any advice.
