Hydraulic tiller driven off your internal hydraulic system No! The Pump in that Hydrostatic transmission does not generate enough Hydraulic pressure to Power a Tiller. Most Manufactures Hydraulic tillers are Driven by a separate PTO Pump( I have two Hydraulic driven Tillers One runs by a shaft driven PTO Pump the Other is a Belt driven PTO Pump) the exception to that is Case/Ingersoll tractors which can generate the pressure You need to run a Tiller and other Hydraulic driven attachments. You might be able to run extra Outlets Later wide frame were able to have 1 set of extra Outlets:thThumbsU
See less
