1 - 1 of 1 Posts
Putting a T.A. in a 1486. Concerned about rear countershaft bearing. After tightening nut and installing retainer, there is approximately 100 thou. of end play on countershaft. Bearing seems to run smoothly. (Case is pretty proud of the bearing at $200) Is this end play acceptable or should I be putting in a new bearing?
Thanks
1 - 1 of 1 Posts
