1 - 11 of 11 Posts
I was reading through the service manual for the 140 (30,000 and up) got to the section on power train and so I went out to look over my tractor and make sure I could find everything and I certainly cannot find the throwout arm and bearing.
I've searched here and on WFM and cannot find anything definitive. Did JD get rid of the engine disconnect on the later model 140's? Any body know why?
Thanks,
Jeff
· THE TRACTOR HUNTER
First, what year is your 140? I assume it is a H3 model or an H1?
The late model >30,000 have the clutch / trany/hydro / engine disconnect. The functionality is different between the early model <30,000 and the late model >30,000 140 H3's. Some say by depressing the clutch only returns your throttle arm back to Neutral. I think it actually disengages the engine from the hydro/trany, just based on how much easier it starts the tractor when depressed, and during shutting it down takes the stress off the engine.
Tanner
Lay on the floor along side of one of your late model 140's. Reach up and press the left peddle with your hand or have someone sit on the tractor and push it down.
Let me know what you see when the peddle is pressed down. :beatdeadh
The early 140's with the early style transmission have an actual clutch disconnect and a "return to neutral feature". The later 140's only have the "return to neutral" feature, but no actual "clutch".
It seems to have happened with the change in rear ends.
Sorry, I fixed my signature so you guys will know what my tractors are. The one I am working on is a '74 H1 model. According to the manual when you press the left pedal, this applies force to a thrust bearing and disengages the clutch from the driveshaft. I can tell you I do not have any linkages/bearings. The only thing that happens is that the forward/reverse lever will return to neutral as Craig said. There are no mechanics involved that would disengage the driveshaft from the engine.
I just wanted to make sure this was correct and that I wasn't missing any parts. Sounds normal. Guess I'll ignore that section of the manual!
Thanks,
Jeff
my 1974 H3 only returns the lever to neutral.
The only reason I could see for the clutch was I would use it to stop the Rototiller It stops all action out of the engine Via drive shaft; I had/rebuilt 7 in my collection and it seams there was small differances on them Yet they were all the same. And in my humble opion They were the best and truely the first garden thector. There only bad point was No power steering. and you put a bucket or blade on it it was hard to steer. Other then that. #1. I sold one a while ago for $3850.00 That is more then they sold for new, Of 7 i still have 1 left it's a work horse. Tiller. bucket. Deck, Blade. Life is so good..
· Likes Vintage JDs
Guys, I know this is an old thread.
But I am reviving it because it is one of the few discussions of this engine-disconnect/neutral-return feature on the 140s. In doing some general parts research, I came across information which answers the o.p.'s question and maybe resolves this small mystery.
Jeff/jphavener was asking whether the later 140s have the engine disconnect feature. The answer is that it depends on how you define "later 140".
My 1972 140 H3 is usually considered a "later model". It has the 14 HP engine, dual drum steering brakes, the new style rear hydrostatic transmission, 1" front spindles, cassette style front wheel bearings, beefier rear axle, new style rear axles and hubs with inboard seals, etc.
And by depressing the left pedal, it also has both the neutral-return and the engine-disconnect feature, just like Glockem's (I believe he was referring to his 1971).
However, the engine disconnect feature was eliminated on 140 H3 models in early 1973 starting with Ser. # 46884. For H1 models, the engine disconnect feature was elminated at the beginning of model year 1972 starting with Ser. # 38001. Note that the change occured at the beginning of 1972 for H1, and a very short-way into model year 1973 for H3 models.
In the schematics below, the first has a clutch assembly (part# 13) which the second lacks. The entire first assembly is called the "engine disconnect drive shaft" style, and the second is simply called the "driveshaft" assembly.
So among the later model 140s, all H1s from 1972 and later will lack the engine disconnect feature. With H3 models, nearly all '73 and all '74 models will lack the engine disconnect feature. 1972 H3s and a very few early '73s have the engine disconnect feature.
I'd say your right my 1974 only has the return to neutral feature which is fine I use it as a speed control often so I only need to advance the hand control in either direction and use the pedal to slow and stop.
· Likes Vintage JDs
Yeah, this would explain why there has been so much confusion. Folks with '73 and '74s have been insisting that the pedal does not disconnect the engine from the tranny. And those of us with earlier models routinely use the pedal at start-up to make for easier starts -- we can hear it connect and spin-up the tranny when we let up on the pedal.
I am pleased my '72 has this feature -- it really does make a big difference when starting, especially in cold weather. It also allows the use of a front 540 PTO or hydraulic pump when stationary without the engine having to power the transmission simultaneously.
My 73 doesn't have it either. Good info UT!
Sent from the MTF Free App
1 - 11 of 11 Posts
