Hi, could be a loose connection some where between stator plug and battery,possible blown fuse? just some possibilities.
Good luck
Good luck
they actually make a contact cleaner just for that.I find that few shots of carb cleaner into the key hole and a number of key turns to make and break the contacts, (without starting the engine), may clean up the switch contacts.
