123 pto
844 Views 2 Replies 3 Participants Last post by  RBedell
Can someone put some pictures up of the front PTO on the 123? I'm not sure if mine is missing something or whats up. When I pull it back to the lock position closest to the driver seat it seems to bog the engine a little. Is that normal?
1 - 3 of 3 Posts
It this with a load on the PTO?
Is the belt on the PTO and powering a attachment when this is happening?
Cause from what you are discribeing you are dis-engaugeing the clutch and it should not bog down the motor when dis-engaugeing.
Is this what you are looking for......?? PTO.
I
1 - 3 of 3 Posts
