If you ever end up with a Bolens tube frame tractor you will like it. As mentioned attachments are pretty available as most will interchange. To give you an idea here are some of the tube frame models with lots of interchangable parts. 1050, 1053, 1054, 1220, 1225, 1253, 1254, 1256, 1257, g10, g11, g12, h14, 1556, h16. These tractors are as well built as the old cubs.
I find them easy to work on with the hh series tech engines or Wisconsin engines. They are mounted with shaft facing front/rear and when the hood is open there is full access to everything. You don't need to remove 1/2 the tin to work on these tractors.
