I bought a 1210 ford tractor knowing the MM PTO didnt work about 3 months ago and after using it desided to change all the fluids and drop the MM PTO to see what was wrong. The gear in the PTO was busted and also the bearing housing in the rear was cracked. The main shaft that runs the tractor has a bearing seat at the end in the rear. I have checked around and parts are scare as hens teeth. Anybody have an extra rear end housing or is this a problem with the 1210 fords. I figure the fellow who owned it hit something really hard to brake this housing and bust the gear. the tractor only has 227 hours on it.
any help at all would be great !!
chuck
chuck
