1 - 2 of 2 Posts
Hello--
The other day when I was mowing my lawn, I came up to a tree, and proceeded to put the tractor into reverse so I could finish the next pass. However, when I went to put it into reverse, the reverse gear had vanished! I knew that something bad was happening, so I tried putting the tractor into another gear, but with no avail. All the gears had essentially "vanished". When that happened, the shifter nob/linkage became very loose, like it wasn't connected to anything. Does that mean that the shifter fork broke? If so, is there a procedure that I could follow on how to repair my transmission?
1 - 2 of 2 Posts
