1 - 3 of 3 Posts
Hi there
I am new here and was needing a little help to remove the steering column from my 1200. It has about 1/8 turn of free play. I had seen some info. about the cover plate being bent. Would like to see if I can tighten it up some. Will it come out the bottom with the deck off, or remove gas tank & tower? I have new rod ends to put on.
:thanku:
bronco65:
(A) You will need to remove the steering wheel.
(B) You will need to remove the drag linkage
(C) There are two (2) bolts at the base of the column that secure the column to the frame, that need to be removed.
Once all the above is done, the steering column will come down from underneath and available for service.
1 - 3 of 3 Posts
