Thanks for the info.:thThumbsUSince the H1 is a '72, it will have a heavier and wider axle then the 1970.
The width between the wheels..Are you referring to the diameter of the axle spindles? Or something else?
In 1972, the diameter of the front axle spindles on the 140 (120 had already been discontinued) was increased to 1".
???? Can't quite see that from the photo. But if so, I might suspect that the 120 has had its axle replaced by a 110/112 axle? I have never seen any mention of a narrower front track on the 120.Thanks for the info.:thThumbsU
So you're saying I have a Frankenstein tractor????? Can't quite see that from the photo. But if so, I might suspect that the 120 has had its axle replaced by a 110/112 axle? I have never seen any mention of a narrower front track on the 120.
This is what I was getting at. Yes, the difference from the tractor to the top of the spindle does look different. But the distance from the tractor to the edge of the wheel rim looks the same to me. It appears that when they beefed up the spindle, they also changed the camber angle, making the axle appear wider but the track width remains the same....
Seems like the camber angle of the spindle might be different as well....
I think you mean 4 1/2" not 5 1/2"...Ok I went outside and measured, smaller is 120 which is 5 1/2" from frame and 37 1/4" outside tire dimensions The 140 is 5 5/8" from frame and 38 1/2" outside tire Demensions. View attachment 256905 View attachment 256913 View attachment 256921 View attachment 256929
Sent from the MTF Free App
Picture looks like about 5 1/2 to me. Where do you come up with 4 1/2 ?I think you mean 4 1/2" not 5 1/2"...
It's 5 1/2" frame to inside wheel not spindle.. Actually 5 5/16"I think you mean 4 1/2" not 5 1/2"...
My mistake, I thought you were measuring where the spindles where in relation to the frame.It's 5 1/2" frame to inside wheel not spindle.. Actually 5 5/16"
