110 W/recoil starter?
846 Views 12 Replies 5 Participants Last post by  Rydplrs
Any early JD 110's with rope start? Found one advertised as 100% original but has manual start (rope pull) ....
1 - 13 of 13 Posts
Only model 60 and 70. Had a hand wind rope option.
The rf 110 does have a rope start spot on the starter generator belt pulley under the belt guard/debris screen though. Hand wound, not a recoil.
my 110 has a rope start groove on the pulley but as far as i know none were sold without electric start.
As others has said no 110 with recoil starters were ever sold. Seems like there have been a bunch of people drop Briggs recoil starts in them....
Do you have any pictures?
Serial # SNT1031058458M
Does look like a Kohler, but like everyone else said, not original. Even back in 63 they were key start.
I agree with SJ, looks like a Kohler but it was replaced at some point and the recoil start was added.
It would be easy to convert it back... but you would need about $300 in parts... PTO cover, Flywheel cover, Starter/Generator... and some other small bits.
Or you could run it like that and have fun. :fing32:
Based on the serial number it is a 1966
Interesting...here is a pic of dash area...I don't see a key switch.
Looks like it was painted over or it missing... cant tell with the shadows... the key switch is right next to the serial number tag....
Deere actually marketed these machines as being triple safe...
1) Key switch
2) Neutral switch
3) PTO swtich
From Tractor data: 1966 would be from 40001-65000...how is that translated from SNT1031058458M ?
SNT1031 is the type code. Type code would specify lift (manual or hydraulic) and tire option... narrow/wide and turf/ag style.
The actual serial number is 058458.... which puts it mid/late 1966.
:fing32:
i wonder if its a K181 pull start
Probably, they were used on man many pieces of equipment.
it might just be a recoil bolted on when the starter generator went bad. charge the battery between uses and pull when you want to start it
1 - 13 of 13 Posts
