1 - 15 of 15 Posts
· Three of my friends
Thinking about a tiller for my 110,found one says it is model 31.What does the tiller drive off of on the 110?
It runs off the mower PTO via a short belt that goes to a special mule drive that mounts in the middle of the tractor where the mower mounts. From there a long belt with a 1/2 a turn twist in it goes back to the tiller. If the mule drive is missing they are in the $100+ range if you need to buy one. Consider that in the purchase price as the mule drive is hard to find. Roger
· Super Moderator
This should Help show You How a 110/112 Square Fender runs the tiller Though it does show a RF in one of the Top diagram Pictures
:thThumbsU
· new nut but loving it
This is not my picture, but it shows the tiller and componets really well.
Good luck with your hunt. :D
Hey Sergeant; that is neat... I have never seen how the tiller was driven on the older round fender 110. :thThumbsU
· Super Moderator
I fixed My Original Post Because I thought the owner had a Round Fender 110 But Here is that Picture again Deerenut
:thThumbsU
:thanku: :D
Good thing these aren't the instructions for the old 160 -185 series, most can't get the rear right wheel off with dynamite :14_6_5:
Discussion Starter · #9 ·
Thanks guys,this person selling it has a pallet loaded with stuff so maybe its all there
Discussion Starter · #11 ·
Got email from the tiller I was looking at and he said he thought it came off a 216,will it work on my sf 110?
· Super Moderator
Yes It will work just Fine On Your SF/Fenderdeck 110:thThumbsU
But as stated You will Need Most of these Parts
Unless You already Have a Integral Hitch On your 110 already The Only thing you Don't Need for the tiller Is Item Number 18 which is the Hitch Its self But Everything else Is need for the Tiller as Far as Mounting it On the Rear and If Your 110 is Manual lift You will want this Spring assist
Now if You have electric Lift on The 110 You would Probably want to get this spring assist for that
Discussion Starter · #13 ·
4 hour trip to ok city to get the tiller and got
a truck bed full of stuff along with the tiller,some may be for the tiller but one part is a almost new deck discharge cover,don't know what it fits.another item was a pair of Goodyear bar tires mounted on rims a small blade, it is Jd and has a hitch like it can be pulled by the tractor.pictures will be later.
Pictures will be great. Looking forward to them. :D
Discussion Starter · #15 ·
Here ya go,tomorrow I will set them out for a group picture and someone knows all the pieces.
1 - 15 of 15 Posts
