1 - 12 of 12 Posts
I can't believe I spent 2 hours sanding a mower deck.:banghead3 Anyway here are some more build pics from the 10525. I removed the entire handle lubed the bail cables, taped off decals and painted the handle and control panel.
http://i192.photobucket.com/albums/z40/GPerinis/Miscellaneous/Picture109.jpg
New bail parts and cable holders...with hardware.
Motor is back together, wheels clean and relubed, trans also cleaned out and re-lubed as wel...carb will be rebuilt today.
I also took the liberty of pressure washing and cleaning the deck to hospital grade before sanding and painting. The underside got painted with this :
...It makes a nice HARD shell, clean stick free surface. Should resist grass clumping and sticking much better than painted or bare aluminum. I put it on thick and its tougher than woodpecker lips.
Truck bed coated deck...
LOL, you can't believe it took two hours, or, you can't believe it's come to this?
Looks good.
· LAWN-BOY-AHOLIC
My local LB dealer had a 10525 with a bad engine that I was hoping to get my hands on as he often gives me his castoffs. But when I asked about it he said he wanted some parts off of it (he uses a 10525 at home). I noticed a few days later it was missing from out back of the store so I assume he has put it up, it too needed a complete deck re-furbish that I would of been happy to give it. I have a spare DF engine and I would of made it look like it just wheeled off the showroom floor. Oh well, you win some and you lose some.
Two hours and that's what you ended up with? Was that hand sanding or using an orbital/palm sander?
I spent 3 hours on my IH and have about 1/16th sanded to the Mag.....I sould have just taken it to work and blasted it.
Discussion Starter · #12 ·
Hand sanding...220 and 400 grit.
1 - 12 of 12 Posts
