1 - 3 of 3 Posts
I took the carb off my LB Duraforce Gold, 10424 cleaned everything up and now I can not remember where the spring hook for the vane hooks on to and the choke lever on to the slide??
Does anyone have a good picture that would show me how to hook back on to the air cleaner case??
What a dummy!!
This is best picture I could find. The top arrow shows where the throttle/choke cable goes. There is a larger hole, second arrow, near the center of the plastic piece that slides to close choke and this is where the governor spring goes. The little white wheel on throttle air vane can be adjusted for more or less tension to raise or lower the speed of the engine if it runs to fast or slow. The throttle/choke cable from the handle will change speeds of the engine. But if it is to slow or fast the white wheel can be turned to bring the RPM's into the correct range of 3200 in fast and usually around 2500 in low speed. The high speed more important and should not be adjusted higher then 3200.
1 - 3 of 3 Posts
