Make sure the reeds are clean and shut while you have the carb off.
Make sure the reeds are clean and shut while you have the carb off.I previously posted a thread "10323 has no power". I replaced both seals and replaced the reeds along with everything else mentioned in the previous thread. This thing still won't run right. It will start right up but it won't build any power. I didn't pull the piston out when I had the cases split to check to see if the rings were broken but I checked the compression with a gage and it read 90 psi. Is that a reasonable amount? I'm thinking it's carb related but can't be sure. Anyone ever run into this issue before? What else could be wrong with the carb?
Mike
